Upgrading from CUCM 7.1.2.31900-1 to 8.5.1.10000-26
I have been asked to put together a brief outline of tasks required to achieve an upgrade CUCM from 7.1.2.31900-1 to 8.5.1.10000-26.  I have read pretty much everything that I can find from Cisco and have put together a brief list of tasks that will be required.  I was hoping one of you genius's would cast a quick eye over my list and see if you can spot anything I may have missed please ?
Observations:
There does not appear to be a direct upgrade path for the call manager from version
7.1.2.31900-1 to either 8.5x or 8.6x.
Would need to go to 7.1.(3b)SU2 first.
Prerequisites:
Ensure we have the relevant software feature License prior to upgrade to 8.5
Ensure we have correct versions of ISO Files ready.
CUCM Upgrade procedure:
- Install RAM upgrade to 4GB in both publisher and Subscriber. (Both MCS7825H4)
- Backup CallManager
- Upgrade CUCM Publisher to 7.1.(3b)SU2
- Switch the first node to the upgraded partition
- Test
- Upgrade CUCM Subscriber to 7.1.(3b)SU2
- Switch Subscriber to Upgraded Partition
- Test (Ensure that database replication is functioning between nodes)
- Upgrade Publisher to 8.5.1.10000-26
- Install Feature License
- Test
- Upgrade Subscriber to 8.5.1.10000-26
- Upgrade Unity Express to minimum version of 7.3, preferably 8.5
- Test
- Go home for Tea and Medals!
Any advise or crtiticiscm will be gratefully recieved.  Thanks...
Blue
Hi Nik,
I believe every thing you have mentioned is correct. To  just add, you will need to rehost the licenses to work it with CUCM 8.5.
Make sure your hardware supports new CUCM by looking to hardware metrix.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
Ronak Patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hall of Fame Super Red
Hi Nik,
Just to add a couple of comments to the good tips from Ronak (+5 "R")
If you ordered the 8.5 upgrade DVD's from Cisco via PUT (Product Upgrade Tool)
the PAK would be included and can be submitted to receive the Software feature
license. We always try to secure the actual "build" DVD's for CUCM versions rather
than the upgrade .iso's just in case you ever need them for DRS.
PUT
http://tools.cisco.com/gct/Upgrade/jsp/productUpgrade.jsp
The other thing I would probably do is to do your CUE upgrade ahead of time just to
lessen the load on the night of the CUCM upgrade. CUE 7.3 and 8.5 are both backward
compatible for use with CUCM 7.x
Table 2: Cisco Unity Express: Unified CM Versions
Cisco Unity Express Versions
2.0.x2.1.x2.2.x2.3.12.3.33.0.x3.1.13.1.23.2.13.2.27.0.x7.1.x7.2, 8.07.3, 8.57.4, 8.6
2.3.22.3.4
Cisco Unified Communications Manager Versions3.3(3), 3.3(4), 4.0(1),
4.0(2)
4.1(2),
4.1(3)
4.2(1),
4.2(3)
4.3(1), 4.3(2)
5.0(1), 5.0(2), 5.0(3),
5.0(4)
5.1(1), 5.1(2),
5.1(3)
6.0(1)
6.1
7.x
8.0
8.5
8.6
NOTE: CUCM version 5.1(1) does not interoperate with CUE version 3.2.x. Before version 5.0, Cisco Unified Communications Manager was known as Cisco Unified CallManager.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/compatibility/cuecomp.htm
And lastly, look into upgrading your phone firmware to the version for your 8.5 build ahead of
time. The phone firmware portion of these upgrades can (and has) tripped many people up
over the years.
Cheers! And best of luck!
Rob
Thanks both of you for your time and comments.  Very usefull.  Do you think it would be advisable to do the upgrade to CUCCM 7.1.(3b)SU2 on a seperate occasion, again to lighten the load on the 8.5 upgrade evening / weekend ?  We do have CUCCX 7.0(1)SR5_Build504, and I believe that this is compatible with CUCM 71.1(3b)SU2 anyway.
Hey Nik,
You are most welcome
I'm a pretty paranoid person so I would separate these tasks if at all possible
just to mitigate the risks (bugs etc.). So I would make the jump to 7.1(3b)su2
during a different maintenance window.
Cheers!
Rob
The only criticism I might have is the test periods you have in between the PUB and SUB switchovers. Since the Applications are running distinct versions at that point, you might find some inconsistencies and weird behaviour with your testing at that point, but it can depend on what you are actually thinking for your test best.
I would roll out a large set of test once both servers have been migrated to the new version, and then give myself a Window for roll back. I would not actively troubleshoot anything weird that might show up in 7.1.3 as we are just passing by it, without intention to stay.
Finally keep in mind your Jtapi Client!!, You might need to do a Resync in your UCCX if the Jtapi client happen to upgrade revision between your 7.1,2 and 7.1..3 CUCM.
Re: Upgrading from CUCM 7.1.2.31900-1 to 8.5.1.10000-26
BIt of an understatement ;-)
With the PUB & SUB on different versions of software, they ain't gonna be talking to each other. You want to minimise the time spent with the cluster in this state, so I wouldn't have much testing in there. The only "test" I'd have, is making sure the PUB comes up cleanly on the new version of software. As soon as it's up, get that SUB switching versions.
Also, that backup you've got scheduled between the PUB & SUB switches will only work for the PUB. I'd skip this entirely. At this stage, you shouldn't be making any DB changes to your system, so a backup is not needed.
GTG
Please rate all helpful posts.
If I'm reading your agena correctly, you're going to install the software on the SUB after you've switched versions on the PUB. I'd change this and do the SUB install as soon as the PUB install has finished. Then once both installs have finished, you can do the switch version on the PUB, followed by the SUB.
A small suggestion: After you've done the switch version on the PUB, use RTMT to monitor the PUB's CPU utilisation. Once the utilisation drops to normal, then switch version on the SUB.
GTG
Excellent points "G-Man" and Robert! +5 each for these great observations
Cheers!
Rob
Hi Rob and company,
I see  no mention of the COP file.  I find myself in the exact same version upgrade situation as Nik and my understanding is that I'll have to install a COP file as follows:
1.  Install COP v1.1 on all existing nodes in 7.1.2.31900-1 cluster
2.  Upgrade cluster to 8.0(3a)SU3
3.  Install Feature License
4.  Upgrade cluster to 8.6(2a)SU1
Does that sound correctomundo?
Amir
Hi Amir,
The cop "refresh upgrade" only applies to 8.6, not 8.5.
HTH,
Chris
Hi Chris,
Thanks for the clarification. The initial poster was upgrading to CUCM 8.5 and I'm going to CUCM 8.6.
Does my basic process sound correct when upgrading to CUCM 8.6 ?
Thanks!
Amir
I'd do the COP *after* the upgrade to 8.0
The COP modifies the installer component within CUCM, so installing it and then installing 8.0 could "undo" that modification.
GTG
1148
