Bronze
Upgrading IOS to support CP-8831
I have a 2921 router running the following IOS
flash0:c2900-universalk9-mz.SPA.152-1.T1.bin
and CME version
#show telephony-service all
CONFIG (Version=8.8)
Version 8.8
Now I want to install CP-8831 phones but the Data Sheet advises I need  CME) Versions 15.3(2)T, PI21, 15.3(3)T, PI22, and later.
I'm looking at installing the following -  c2900-universalk9-mz.SPA.153-3.M3.bin
Once installed - should the telephony service all still be intact without causing any problems as this is a production router. I'm hoping it's just a case of installing the new IOS, boot and everything works as normal. Does the CME version change with the new IOS install?
1 REPLY
Yes, the CME version is
Yes, the CME version is directly tied to the IOS version.
java
if this helps, please rate
www.cisco.com/go/pdi
170
