08-31-2014 11:45 PM - edited 03-16-2019 11:58 PM
We have two MCS-7825-H2 servers we are planning to upgrade CUCM from the version 6 to 9 and 7 to 9,since Version 10 supports on virtualization,we cannot go for major hardware changes,technically i gone through some doccuments
My queries are When i upgrading to Latest version do i need to buy a new licenses or i can migrate existing licenses,if it is migrating old licenses what are the procedure i need to follow?
Do i need to order services or any support,suggest me on this,only concern is i am planning to upgrade the ram to support compatibility of the version is there any major issue i will face during upgrade.
09-01-2014 01:10 AM
7825H2 does not support CUCM 9 .
you can check H/W compatibility matrix
http://www.cisco.com/c/en/us/products/collateral/unified-communications/7800-series-media-convergence-servers/prod_brochure0900aecd8062a4f9.html
You also need to have UCSS /ESWcontract if u are doing major upgrades.
If u do not have that, u need to order Migration licenses.
regds,
aman
09-01-2014 01:19 AM
Aman its 7825H3
09-01-2014 01:35 AM
I checked , it is supported
regds,
aman
09-01-2014 01:47 AM
S Aman i also gone through early its supporting,i just need to upgrade the ram to 4gb, we dont have UCSS /ESWcontract,so in this case we cannot migrate licenses from old cucm?
09-01-2014 01:54 AM
u need to upgrade the DRAM.
If u do not have contract, then, u need to order migration licenses as per users.
regds,
aman
