Upgrading Unity server from ver. 5.0 to Unity Connection version 8.x
peternnaji
Hello all,
Please what are the steps/procedures to upgrade Unity server from version 5.0 to Unity Connection version 8.x.
What is the part number of the software that will be used for the upgrade and how many hops will this upgrade take?
prompt responses will be appreciated.
Best Regards,
Peter Nnaji.
testeven
Hi Peter,
First of all check if the current hardware you have supports CUC, probably you are ordering new servers, but you might want to check this link:
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/supported_platforms/8xcucspl.html
Then, you'll need to use the COBRAS tool to migrate all the information from Unity to Unity Connection. You can download the tool from:
http://www.ciscounitytools.com/Applications/General/COBRAS/COBRAS.html
Here you'll find an overview of the tool and what data is migrated:
http://www.ciscounitytools.com/Applications/General/COBRAS/Help/COBRAS.htm
If you are a registered partner, for presales (part numbers, BoM, licensing and ordering questions) you can open a case online at:
www.cisco.com/go/partnerhelp
Tere.
If you find this post helpful, please rate!
Regards, Tere. If you find this post helpful, please rate! :)
