Upgrare standalone ELM to PLM.
Hi all.
I want to upgrade my standalone ELM to PLM. Is it possible or I need to install the new PLM and transfer my license to it because there is the different in vm template ? ELM require 1x 80 GB of vDisk and PLM require  1x 50 GB of vDisk.
You can upgrade, if you want
You can upgrade, if you want to use the smaller HDD ova, you would need to do a fresh install and migrate the licenses.
java
if this helps, please rate
www.cisco.com/go/pdi
Will i get eny erroro about
Will i get eny error about vDisk afterupgrade ? Does TAC support this confuguration ?
71
