Community Member
Upgrating CCM Operaiting system to 2000-4.4
My CCM servers are installed with Windows 2000 2.7 version of the CISCO OS. I want to upgrade them to 4.4. I can't find the download of win-OS-Upgrade-K9.2000-4-4.exe. All I can find are updetes (the latest one is SR3). They can only be installed on 4.4. Any ideas where I can download the 4.4 update?
Re: Upgrating CCM Operaiting system to 2000-4.4
Did you read the 4.4 release notes to see if your server model is compatible with 4.4?
OS 2000.4.4 media comes with the servers compatible with it. From what I have seen, main OS updates are only put on CCO if they can be used on any or a majority of the server models without problem. The SR updates are there so people with the servers that came with 4.4 media can update their systems. When 4.3 first came out, it was awhile before cisco got OS 2000.4-3 main update on CCO for a majority to use.
I couldnt find 4-4, but i could find 2000.4.3a. Check in the archives section.
You can upgrade to 4.3a directly from 2.7.
PS: please remember to rate posts!
Community Member
OS 2000.4.4 was pulled from public download access due to the following bug defect:
CSCsh47276 -
Symptom: OS upg to 2000.4.4 can cause motherboard failure for IBM server models MCS-7845-I1-IPC1, MCS-7845-I1-ECS1
Conditions: OS upg from 2000.4.1 and 2000.4.2 to OS 2000.4.4
Workaround: none
Further Problem Description: If you have the servers model above, please avoid upg to 2000.4.4 until there is a resolution for this defect.
