No, these are all the commands you can use but there isn't one to upload directly via CLI
Command Line Interface Reference Guide for Cisco Unified Communications Solutions Release 7.1(3)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cli_ref/7_1_3/cli_ref_713.html
You need to use the GUI
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
