Community Member
upload firm failed with 7921on ccmexp
hi all ,
I installed a 7921 on a ccmexpress 4.1 platform 2811 ios 12.4.15.T1 and at boot time i've got upload firmware failed from my 7921 here are piece of conf it appears too than french isn't yet supported
tftp-server flash:CP7921G-1.0.1.LOADS
tftp-server flash:APPS-1.0.1.SBN
tftp-server flash:GUI-1.0.1.SBN
tftp-server flash:SYS-1.0.1.SBN
tftp-server flash:TNUX-1.0.1.SBN
tftp-server flash:TNUXR-1.0.1.SBN
tftp-server flash:WLAN-1.0.1.SBN
(these files are on my flash)
no auto-reg-ephone
load 7921 CP7921G-1.0.1
(i created the cnf-file)
ephone 23
mac-address XX
ephone-template 1
username "xxx" password XX
type 7921
and some deb tftp
TFTP: Looking for CTLSEP001BD458A80A.tlv
TFTP: Looking for SEP001BD458A80A.cnf.xml
TFTP: Opened system:/its/SEP001BD458A80A.cnf.xml, fd 0, size 1138 for process 152
TFTP: Finished system:/its/SEP001BD458A80A.cnf.xml, time 00:00:00 for process 152
TFTP: Looking for Ringlist.xml
TFTP: Opened flash:RingList.xml, fd 0, size 2842 for process 152
TFTP: Finished flash:RingList.xml, time 00:00:00 for process 152
TFTP: Looking for DistinctiveRingList.xml
TFTP: Opened flash:DistinctiveRingList.xml, fd 0, size 495 for process 152
Sep 28 11:58:03.711: TFTP: Finished flash:DistinctiveRingList.xml, time 00:00:00 for process 152
TFTP: Looking for French_France/7921-dictionary.xml
TFTP: Looking for French_France/7921-kate.utf-8.xml
TFTP: Looking for French_France/7921-font.dat
is the prcess stopping because lack of french?
thanks for help
Hall of Fame Super Gold
Re: upload firm failed with 7921on ccmexp
from the documentation, the 7921 supports French.
And, 1.0.1 is not the latest release (that you should use).
I haven't looked for 7921 specifically, but you can find the 'locale' for phone on CCO download. The files are the same for CM or CME.
That would allow you to copy to the router and use the 'alias' option in tftp-server to allow the phone access them.
