Community Member
Uploading Files to CUCM 7.1
I have a customer that gets a file containing cmc's sent to them everyday. Is there a way to have these files automatically uploaded from their server to the CUCM server. Then I would have bat insert the new codes via a job that is schdule to run everyday. Is this possible?
1 REPLY
Re: Uploading Files to CUCM 7.1
Unfortunately we do not have a mechanism that allows you to schedule uploading files for BAT usage.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
142
