08-02-2007 12:35 PM - edited 03-14-2019 10:54 PM
i don't know how to upload the gui files to the 2821 IP pbx.
i set up a tftp server and i'm able to upload firmwares but the "archive tar" command isn't working.. any help ?
Solved! Go to Solution.
08-03-2007 06:31 AM
TFTP the tar file to the router to make sure that the router actually can get to that file and that there isn't some crazy computer thing going on. What version of IOS, model of router, and TFTP client are you using? I am going to try it here...
Scott
08-02-2007 01:23 PM
The following command doesn't work?
Router# archive tar /xtract tftp://ip-address/filename flash:
If not, what error do you show?
08-03-2007 05:28 AM
this is what i'm getting
IP-PBX#archive tar /xtract tftp://10.1.30.100/cme.gui-3.3.0.3a.tar flash:
%Error opening tftp://10.1.30.100/cme.gui-3.3.0.3a.tar (No such file or director
y)
08-03-2007 06:31 AM
Scott
