Uploading Remote Destination Profiles via BAT
I have a CUCM 7.1(3) system and have a requirement to give serveral users remote destination profiles.  I noticed that there is a BAT workbook tab to bulk in RDPs but in CUCM when I go to create a RDP BAT template it specifically requests for the user ID.  To me this appears to defeat the purpose of a template and it appears that the bulk upload works well for updates to existing RDPs and not to bulk in new profiles.  My question is have you been able to successfully bulk new RDPs or is the BAT more geared towards updating existing RDPs.
Edwin
1 REPLY
Hall of Fame Super Red
Re: Uploading Remote Destination Profiles via BAT
Hi Edwin,
You should be able to override any settings within the Template based on
the info in the .csv
Inserting Remote Destination Profiles into Cisco Unified CallManager
Use the following procedure to insert Remote Destination Profiles into Cisco Unified CallManager
Procedure
Step 1 Choose Bulk Administration > Remote Destination Profile > Remote Destination Profile Insert.
The Insert Remote Destination Profile Configuration window displays.
Step 2 In the File Name drop-down list box, choose the CSV data file that you created for this specific bulk transaction.
Step 3 In the Remote Destination Profile Template Name drop-down list box, choose the BAT Remote Destination Profile template that you created for this type of bulk transaction.
Note Remote Destination Profile template is optional while inserting Remote Destination Profiles. Ensure that the CSV data file has a `Desk Phone Name' when a Remote Destination Profile template is not selected.
Step 4 Checking the Override the existing configuration check box overwrites the existing Remote Destination Profile settings with the information that is contained in the file that you want to insert.
Step 5 In the Job Information area, enter the Job description.
Step 6 To insert the Remote Destination Profile records immediately, click the Run Immediately radio button or click Run Later to insert the Remote Destination Profile records at a later time.
Step 7 To create a job for inserting the Remote Destination Profile records, click Submit.
Step 8 Use the Job Configuration window to schedule and/or activate this job.
http://cisco.biz/en/US/docs/voice_ip_comm/cucm/bat/6_0_1/t11dstpr.html#wp1047290
Cheers!
Rob
1157
