10-05-2013 10:22 AM - edited 03-16-2019 07:43 PM
Dear All
I have this scenarion :
my mobile calling ----> 22279789 (DID"789") ----> open new session or new call to call mobile or land line and international by FXO code " 64"
the problem is : when i make calling from my mobile to 22279789 , then open TOOT to put (any number international or local ) ----> wait 20 seconds then gives me "busy tone"
please see on the configuration below to see what is missing or not correct , and how to solve this issue ? please also find the attached file for debug and show run
My configuration is as following :
On CUCM :
CSS
CSS-Local : PT-local
CSS-International : PT-INT
Route pattern :
6xxxxxxx (Mobile line) : PT-local , mask : 222797XX , disard : none , Prefix : none
2xxxxxxx (Land line) : PT-local , mask : 222797XX , disard : none , Prefix : none
00! (International ) : PT-INT , mask : 222797XX , disard : none , Prefix : none
84 (to open new session) : PT-Local , mask : 222797XX , disard : none , Prefix : none
789 : PT-local , mask : 222797XX , disard : none , Prefix : none
Gateway : CSS-INT
Phone Extesnions : 7xx to 799 , CSS-Local
On Voice Router
dial-peer voice 200 pots
destination-pattern 84T
port 0/0/0
dial-peer voice 201 pots
port 0/0/1
dial-peer voice 10 voip
description ## OUTGOING CALL ##
destination-pattern .T
voice-class codec 2
session protocol sipv2
session target ipv4:10.200.200.253
incoming called-number .
dtmf-relay sip-notify rtp-nte
no vad
dial-peer voice 20 voip
description ## INCOMING CALL ##
huntstop
answer-address 222797..
destination-pattern 222797..
voice-class codec 1
session target ipv4:10.10.10.10
dtmf-relay h245-signal h245-alphanumeric
no vad
num-exp 22279789 64 dial-peer voice 10 voip
voice-class codec 2
no vad
huntstop
voice-class codec 1
session target ipv4:10.10.10.10 ( Publisher Server IP address)
no vad
num-exp 22279789 84
10-05-2013 11:09 AM
Please Help ?
10-05-2013 12:09 PM
in the pots dial-peer you are not sending mobile number, you are sending 64 .
also you need forward-digits all under the pots dial-peer
Anas
please rate all helpful postsd
10-05-2013 12:24 PM
Dear Anas
thanks for ur reply
Do u you mean i need to make it like that ?
Dial-peer pots
destinationa-patern 646...... ---> mobile line number
forward-digits all
port 0/0/0
Dial-peer pots
destinationa-patern 642...... ---> land line number
forward-digits all
port 0/0/0
do u think the problem from route pattern becasue there is mis matching between 64.! and 6...... and 2...... becasue ! means any number so if i put 69602233 it will confuse with route pattern will take 64.! or 6...... ? do u think this problem ?
10-05-2013 12:31 PM
for the route pattern matching. it will match the more specific.
for example, if we have 2 route patterns: 642!, and 6!
when we send 642553333 it will match 642!
when we send 65555 it will match 6!.
the best practice is to create the most specific route patterns to remove the overlaps.
for the dial-peer I mean what you write.
also remove the num-exp command
Anas
10-05-2013 12:41 PM
the best solution i will replace 64 code to 84 , to remove overlaps .
regarding international rdial-peer will be
dial-peer pots
destination-pattern 8400T
forward-digits all
port 0/0/0
I dont think i need to remove the num-exp , how the call will go to pots dial-peer if remove num-exp ?
22279789 84
i think should be configured , is it right ?
10-05-2013 01:01 PM
the nump-exp will change 2229789 to 84 , 84 is the code not the number, right ?
Anas
10-05-2013 01:08 PM
Yes , it is code to open new seesion or new call by FXO (dial-peer pots ... destination-pattern 84)
and keep this command
num-exp 22279789 84
it will be like that
dial-peer pots
destination-pattern 8400T------> international number
forward-digits all
port 0/0/0
Dial-peer pots
destinationa-patern 846...... ---> mobile line number
forward-digits all
port 0/0/0
Dial-peer pots
destinationa-patern 842...... ---> land line number
forward-digits all
port 0/0/0
num-exp 22279789 84
regarding CUCM , do i need remove 84.! ot keep it ?
10-05-2013 01:26 PM
Dear Anas
is it right ?
did u face this scenario before ?
10-05-2013 01:42 PM
Any reply plz ?
10-05-2013 01:52 PM
84! in the call manager is not needed.
it is prefered to use 8400! for international
846! for mobile
842! for land
it is prefered to remove the num-exp, I think it is not needed.
Anas
10-05-2013 02:04 PM
thanks anas , i will update you tomorrow .
10-05-2013 10:35 PM
Dear Anas
Still not working , what u think ?
Any Help All ?
thanks
10-06-2013 03:24 AM
Dear All
PlZ Help ?
10-06-2013 04:23 AM
please find the attached files for debug and show run
