**URGENT**FXO code problem to make call to ext ,local lines,international
    Dear All
I have this scenarion :
my mobile calling ----> 22279789 (DID"789") ----> open new session or new call to call mobile or land line and international by FXO code  " 64"
the problem is : when i make calling from my mobile to 22279789 , then open TOOT  to put (any number international or local ) ----> wait 20 seconds then gives me "busy tone"
please see on the configuration below to see what is missing or not correct , and how to solve this issue ? please also find the attached file for debug and show run
My configuration is as following :
On CUCM :
CSS
CSS-Local : PT-local
CSS-International : PT-INT
Route pattern :
6xxxxxxx (Mobile line) : PT-local , mask : 222797XX , disard : none , Prefix : none
2xxxxxxx (Land line)  : PT-local , mask : 222797XX , disard : none , Prefix : none
00! (International )    : PT-INT  , mask : 222797XX , disard : none , Prefix : none
84 (to open new session)  : PT-Local , mask : 222797XX , disard : none , Prefix : none
789 : PT-local , mask : 222797XX , disard : none , Prefix : none
Gateway : CSS-INT
Phone Extesnions : 7xx to 799 , CSS-Local
On Voice Router
dial-peer voice 200 pots
destination-pattern 84T
port 0/0/0
dial-peer voice 201 pots
port 0/0/1
dial-peer voice 10 voip
description ## OUTGOING CALL ##
destination-pattern .T
voice-class codec 2
session protocol sipv2
session target ipv4:10.200.200.253
incoming called-number .
dtmf-relay sip-notify rtp-nte
no vad
dial-peer voice 20 voip
description ## INCOMING CALL ##
huntstop
answer-address 222797..
destination-pattern 222797..
voice-class codec 1
session target ipv4:10.10.10.10
dtmf-relay h245-signal h245-alphanumeric
no vad
num-exp 22279789 64 dial-peer voice 10 voip
voice-class codec 2
no vad
huntstop
voice-class codec 1
session target ipv4:10.10.10.10 ( Publisher Server IP address)
no vad
num-exp 22279789 84
Please Help ?
in the pots dial-peer you are not sending mobile number, you are sending 64 .
also you need forward-digits all under the pots dial-peer
Anas
please rate all helpful postsd
Dear Anas
thanks for ur reply
Do u you mean i need to make it like that ?
Dial-peer pots
destinationa-patern 646...... ---> mobile line number
forward-digits all
port 0/0/0
Dial-peer pots
destinationa-patern 642...... ---> land line number
forward-digits all
port 0/0/0
do u think the problem from route pattern becasue there is mis matching between 64.! and 6...... and 2...... becasue ! means any number so if i put 69602233 it will confuse with route pattern will take 64.! or 6...... ?  do u think this problem ?
for the route pattern matching. it will match the more specific.
for example, if we have 2 route patterns: 642!, and 6!
when we send 642553333 it will match 642!
when we send 65555 it will match 6!.
the best practice is to create the most specific route patterns to remove the overlaps.
for the dial-peer I mean what you write.
also remove the num-exp command
Anas
the best solution i will replace 64 code to 84 , to remove overlaps .
regarding international rdial-peer will be
dial-peer pots
destination-pattern 8400T
forward-digits all
port 0/0/0
I dont think i need to remove the num-exp , how the call will go to pots dial-peer   if remove num-exp ?
22279789 84
i think should be configured , is it right ?
the nump-exp will change 2229789 to 84 , 84 is the code not the number, right ?
Anas
Yes , it is code to open new seesion or new call by FXO (dial-peer pots ... destination-pattern 84)
and keep this command
num-exp  22279789 84
it will be like that
dial-peer pots
destination-pattern 8400T------> international number
forward-digits all
port 0/0/0
Dial-peer pots
destinationa-patern 846...... ---> mobile line number
forward-digits all
port 0/0/0
Dial-peer pots
destinationa-patern 842...... ---> land line number
forward-digits all
port 0/0/0
num-exp  22279789 84
regarding CUCM , do i need remove 84.! ot keep it ?
Dear Anas
is it right ?
did u face this scenario before ?
Any reply plz ?
84! in the call manager is not needed.
it is prefered to use 8400! for international
                             846! for mobile
                             842! for land
it is prefered to remove the num-exp, I think it is not needed.
Anas
thanks anas , i will update you tomorrow .
Dear Anas
Still not working , what u think ?
Any Help All ?
thanks
Dear All
PlZ Help ?
please find the attached files for debug and show run
make a call and collect logs for "debug dial-peer"
regards
Anas
please check
Oct  6 12:39:44.759: //-1/367D275E97DB/DPM/dpAssociateIncomingPeerCore:
   Calling Number=pinger, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=NO_MATCH(-1) After All Match Rules Attempt
Oct  6 12:39:46.759: //-1/50DE69918FF4/DPM/dpAssociateIncomingPeerCore:
   Calling Number=69602459, Called Number=22279789, Voice-Interface=0x0,
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=10
Oct  6 12:39:46.763: //308/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
   Call Entry Is Not Found
Oct  6 12:39:46.763: //-1/50DE69918FF4/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=69602459
   ----- ccCallInfo IE subfields -----
   cisco-ani=69602459
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=22279789
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=-1
Oct  6 12:39:46.763: //-1/50DE69918FF4/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x64142DC0, Call Info(
   Calling Number=69602459(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=22279789(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=10, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=308
Oct  6 12:39:46.763: //-1/50DE69918FF4/CCAPI/ccCheckClipClir:
   In: Calling Number=69602459(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=69602459(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Oct  6 12:39:46.763: //308/50DE69918FF4/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=69602459(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=22279789(TON=Unknown, NPI=Unknown))
Oct  6 12:39:46.767: //308/50DE69918FF4/CCAPI/cc_process_call_setup_ind:
   Event=0x642B16C8
Oct  6 12:39:46.771: //308/50DE69918FF4/CCAPI/ccCallSetContext:
   Context=0x633ED3D0
Oct  6 12:39:46.771: //308/50DE69918FF4/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 308 with tag 10 to app "_ManagedAppProcess_Default"
Oct  6 12:39:46.771: //308/50DE69918FF4/CCAPI/ccCallProceeding:
Oct  6 12:39:46.771: //-1/50DE69918FF4/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=22279789, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=22279789
Oct  6 12:39:46.775: //-1/50DE69918FF4/DPM/dpMatchPeersCore:
   Result=Success(0) after DP_MATCH_DEST
Oct  6 12:39:46.775: //-1/50DE69918FF4/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=200
     2: Dial-peer Tag=203
     3: Dial-peer Tag=204
     4: Dial-peer Tag=202
     5: Dial-peer Tag=201
     6: Dial-peer Tag=207
     7: Dial-peer Tag=205
     8: Dial-peer Tag=206
     9: Dial-peer Tag=10
Oct  6 12:39:46.775: //308/50DE69918FF4/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=200, Params=0x633EC7C0, Progress Indication=NULL(0)
Oct  6 12:39:46.775: //308/50DE69918FF4/CCAPI/ccCheckClipClir:
   Destination Pattern=84T, Called Number=84, Digit Strip=TRUE
   Called Number=84(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=
   Account Number=69602459, Final Destination Flag=TRUE,
   Guid=50DE6991-2DBA-11E3-8FF4-C46413F60520, Outgoing Dial-peer=200
Oct  6 12:39:46.775: //308/50DE69918FF4/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=69602459
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=84
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Oct  6 12:39:46.775: //308/50DE69918FF4/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x642EFD68, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=69602459(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=84(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=200, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Oct  6 12:39:46.775: //309/50DE69918FF4/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Oct  6 12:39:46.779: //309/50DE69918FF4/CCAPI/ccCallSetContext:
   Context=0x633EC770
Oct  6 12:39:46.779: //308/50DE69918FF4/CCAPI/ccSaveDialpeerTag:
Oct  6 12:39:46.779: //309/50DE69918FF4/CCAPI/cc_api_call_proceeding:
   Interface=0x642EFD68, Progress Indication=NULL(0)
Oct  6 12:39:48.030: //309/50DE69918FF4/CCAPI/cc_api_call_disconnected:
   Cause Value=34, Interface=0x642EFD68, Call Id=309
   Call Entry(Responsed=TRUE, Cause Value=34, Retry Count=0)
Oct  6 12:39:48.030: //309/50DE69918FF4/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=309
Oct  6 12:39:48.030: //309/50DE69918FF4/CCAPI/ccCallDisconnect:
   Cause Value=34, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=34)
   Cause Value=34, Call Entry(Responsed=TRUE, Cause Value=34)
Oct  6 12:39:48.034: //309/50DE69918FF4/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x642EFD68, Tag=0x0, Call Id=309,
   Call Entry(Disconnect Cause=34, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Oct  6 12:39:48.034: //308/50DE69918FF4/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=203, Params=0x633EECE0, Progress Indication=NULL(0)
Oct  6 12:39:48.034: //308/50DE69918FF4/CCAPI/ccCheckClipClir:
Oct  6 12:39:48.038: //308/50DE69918FF4/CCAPI/ccCheckClipClir:
Oct  6 12:39:48.038: //308/50DE69918FF4/CCAPI/ccCallSetupRequest:
   Guid=50DE6991-2DBA-11E3-8FF4-C46413F60520, Outgoing Dial-peer=203
Oct  6 12:39:48.038: //308/50DE69918FF4/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=69602459
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=84
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Oct  6 12:39:48.038: //308/50DE69918FF4/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x642F627C, Interface Type=6, Destination=, Mode=0x0,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=203, Call Count On=FALSE,
Oct  6 12:39:48.038: //310/50DE69918FF4/CCAPI/ccIFCallSetupRequestPrivate:
Oct  6 12:39:48.038: //310/50DE69918FF4/CCAPI/ccCallSetContext:
   Context=0x633EEC90
Oct  6 12:39:48.038: //308/50DE69918FF4/CCAPI/ccSaveDialpeerTag:
Oct  6 12:39:48.042: //310/50DE69918FF4/CCAPI/cc_api_call_proceeding:
   Interface=0x642F627C, Progress Indication=NULL(0)
Oct  6 12:39:48.542: //310/50DE69918FF4/CCAPI/cc_api_call_alert:
   Interface=0x642F627C, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
Oct  6 12:39:48.542: //308/50DE69918FF4/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, AlertSent=TRUE)
Oct  6 12:39:48.542: //308/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x64838D54, callID1=0x134, callID2=0x136, tag=0x0)
Oct  6 12:39:48.542: //308/50DE69918FF4/CCAPI/ccConferenceCreate:
   Conference Id=0x64838D54, Call Id1=308, Call Id2=310, Tag=0x0
Oct  6 12:39:48.542: //308/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Oct  6 12:39:48.542: cc_api_get_xcode_stream : 4181
Oct  6 12:39:48.542: //308/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x6D, Source Interface=0x64142DC0, Source Call Id=308,
   Destination Call Id=310, Disposition=0x0, Tag=0x0
Oct  6 12:39:48.542: //310/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x6D, Source Interface=0x642F627C, Source Call Id=310,
   Destination Call Id=308, Disposition=0x0, Tag=0xFFFFFFFF
Oct  6 12:39:48.542: //308/50DE69918FF4/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x6D, Destination Call Id=310)
Oct  6 12:39:48.546: //310/50DE69918FF4/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x6D, Destination Call Id=308)
Oct  6 12:39:48.546: //310/50DE69918FF4/CCAPI/cc_api_caps_ind:
   Destination Interface=0x64142DC0, Destination Call Id=308, Source Call Id=310,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=250(ms), Fax Nom=300(ms))
Oct  6 12:39:48.546: //308/50DE69918FF4/CCAPI/cc_api_caps_ind:
   Destination Interface=0x642F627C, Destination Call Id=310, Source Call Id=308,
   Caps(Codec=0x800, Fax Rate=0x2, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=2)
Oct  6 12:39:48.546: //308/50DE69918FF4/CCAPI/cc_api_caps_ack:
   Caps(Codec=g729br8(0x800), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=20, Signal Type=2, Seq Num Start=6438)
Oct  6 12:39:48.546: //310/50DE69918FF4/CCAPI/cc_api_caps_ack:
Oct  6 12:39:48.550: //308/50DE69918FF4/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x6D, Call Id1=308, Call Id2=310
Oct  6 12:39:48.550: //310/50DE69918FF4/CCAPI/cc_api_voice_mode_event:
   Call Id=310
   Call Entry(Context=0x633EEC90)
Oct  6 12:39:48.550: //310/50DE69918FF4/CCAPI/cc_api_call_connected:
   Interface=0x642F627C, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Oct  6 12:39:48.554: //308/50DE69918FF4/CCAPI/ccCallConnect:
   Progress Indication=DESTINATION IS NON ISDN(2), Data Bitmask=0x1
   Call Entry(Connected=TRUE, Responsed=TRUE)
Oct  6 12:39:58.569: //308/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 2 to dstCallId 0x136
Oct  6 12:39:58.909: //308/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
Oct  6 12:39:59.209: //308/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 4 to dstCallId 0x136
Oct  6 12:39:59.537: //308/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
Oct  6 12:39:59.929: //308/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 9 to dstCallId 0x136
Oct  6 12:40:00.249: //308/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
Oct  6 12:40:00.557: //308/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 5 to dstCallId 0x136
Oct  6 12:40:00.817: //308/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
Oct  6 12:40:01.241: //308/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 0 to dstCallId 0x136
Oct  6 12:40:01.521: //308/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
Oct  6 12:40:01.921: //308/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
Oct  6 12:40:02.181: //308/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
Oct  6 12:40:02.481: //308/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
Oct  6 12:40:02.933: //308/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
Oct  6 12:40:03.501: //308/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
Oct  6 12:40:03.861: //308/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
VG-KC#
Dear Anas
thanks for helping again
please I am waiting your help , i am on site if you can give me ur adive ASAP
thanks
add forward-digits all under the dial-peer 201 - 208 and test
regards
I did
when i put , directly gives me busy tone
under dial-peer voice 10 voip
port the below command
" voice-class codec 1"
Anas
Dear Anas
i changed it but still it is not working
see in the debug above
after open session i put this number for testing : 24950500
and see below in the bold  the deubg :
   Consume mask is not set. Relaying Digit 0 to dstCallId 0x136 Oct  6 12:39:58.569: //308/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
Dear Anas
Consume mask is not set , it is DTMF issue , and i searched it is rtp issue in  sip provider may be , do u think the problem from SIP provider ?
Dear All
any updates , still the problem not solved ?
536
