URGENT HELP IS NEEDED......
i have configured CCME on a router and i am using a VG224 for analog phones.i need to transfer a call from analog to other extensions(analog and ipphones).i have enabled supplementary-services h450.12 and i gave allow connection h323 to h323.these i have done.i am able to transfer calls from ipphones to analog extensions.but what i have to do to transfer analog to analog or analog to ipphone???i have configured VG224 as h323 gateway..please help me....its urgent....
Re: URGENT HELP IS NEEDED......
You should consider registering your VG224 analog ports as SCCP endpoints in the CCME. This will allow supplementary-services to be extended to these ports. See this document:
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t2/ht1vg224.html
Your other option is to run a the app_h450_transfer tcl script on the VG224. That will allow you to perform hookflash transfers on your analog ports.
For this option, see this document:
http://www.cisco.com/en/US/docs/ios/voice/tcl/developer/guide/tclivrv2_ch2.html
I've done both methods, and I would suggest that you enable SCCP control and let CCME extend the supplementary services.
Hall of Fame Super Gold
Excellent above information from Adam that I've rated "5".
i have tried to configure VG224 as a SCCP gateway.what i have done is:
#conf t
#sccp local
#sccp ccm identifier 1 version 3.3
#sccp
#sccp ccm group
#associate ccm 1 priority 1
#exit
When i have typed the "#show sccp" command;
this message shows....
"sccp parameters are not activated (dspfarm profiles)or not associated with ccm group"
Then i came to know that dsp farm needs to be created.
I have dsp module in CCME router...
But what i have to do to integrate this ....???
Can you please give me the detailed configuration steps...???
i am stuck with this........
please please help me.........
Thanks in advance.........
Here is the document which explains to create a dsp farm.
The information in this document is based on these software and hardware versions:
Cisco CallManager version 4.0(1)
Cisco IOS Software Release 12.2(15)T13 IP Plus
Cisco 2651 Gateway
NM-HDV with two Packet Voice DSP Module (PVDM) DSP Single In-line Memory Modules (SIMMS)
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080334294.shtml
I am facing the same situation where I have a CCME with VG224 configured as H.323 peer and not SCCP (we had to since we dont have free ports on the CCME).
I wish to initiate a call transfer from an analog phone connected to the VG224 by using the second method (the script, hookflash).
I have downloaded the app-h450-transfer.2.0.0.4.tcl script and copied it to the flash of the VG224.
The following is my configuration on the VG224:
application
service transfer slot0:app-h450-transfer.2.0.0.4.tcl
paramspace english language 1
dial-peer voice 11 pots
corlist incoming BAC-CSS-GSM
corlist outgoing call-Internal
description --- science lab
service transfer
destination-pattern 3341
port 2/1
where the phone is connected to port 2/1
I have loaded the application (call application voice load transfer)
I still can not transfer a call from an analog phone.
Am I missing something in the config?
How did u get it work by using the tcl script?
I would be very thankful if you can help me on this issue.
regards
219
