Silver
Urgent help need- call routing
I have a site with the following
Central site Remote Site
CCM>>>>>>>>GW>>>>>WAN>>>>>GW>>>>>>>>>PABX
I`m now looking to roll out a pilot with a small number of users off the PABX in the remote location but keep the connection to the local PABX via a Q Sig GW
Outgoing calls
All outgoing calls from the pilot users at the remote site will be via a SRST router on site connecting via a Q Sig. to the local PABX. I will set up a route pattern pointing to the local Qsig GW via the PABX so to route calls to the PABX
Inbound
PABX >>>>>>>SRST router
The idea is that if a PABX user dials an IPT pilot user, the PABX is configured to route the call to the local QSig/ SRST GW
The SRST GW has a dial-peer with a destination pattern of the Pilot IPT users pointing to the of the CCM
Call Signalling goes to the CCM
The CCM instructs the call to the local IPT pilot user- - where does the Voice traffic route via ? - local to the router i.e only call control is across the WAN but voice is on the local LAN or via the WAN ? i.e Remote site >>>>Central CCM>>>>>Remote site >>>>>Pilot IPT handsets
thanks
Silver
Re: Urgent help need- call routing
If I read your question correctly, the RTP stream will be between the Voice gateway and the IP Phone. You can verify this with a sniffer trace (ie: wireshark)
If two IP phones at remote sites call one another, the RTP stream will be between the two IP Phones.
IP phone at central site, IP phone at remote site. RTP stream will go over WAN (between the two phones.)
Central site IP Phone to PB phone. RTP stream will be between Central site IP Phone and SRST router / OABX voice gateway at remote site.
I was going to give conference call examples, but decided not to since there are multiple configuration options.
Silver
Thanks for the reply, what I trying to do for the pilot is to have no voice across the WAN.
IPT to IPT calls on the remote site- RTP lcoal on their LAN
So calls from the remote IPT handsets will go via the PABX conenct via their SRST/ Qsig GW.-
Calls form the Central IPT CCM to PABX will go via PSTN so again not WAN traffic
Calls from Central IPT handsets to remote IPT handsets will again goes via PSTN/ PABX
I`m happy with the above
Calls from the PABX to the Pilot IPT on its own site- I need confirmation on
PABX sends the call request to the SRST/Qsig GW it is connected to. Call Signalling goes across the WAN to CCM- happy with this , Remote IPT handset at the PAXB site rings- where does the speech path - acorss the WAN or local?
thanks again
Silver
Between the voice gateway (connecting the PABX) and the IP Phone.
If you don't want anything going across the WAN, turn off music on hold from the callmanger leaving tone on hold because music will stream from the CallManager.
You will have to configure hardware conferencing on the PABX gateway also since conference calls will be mixed and sourced from the CallManager.
119
