urgent help on time of the day routing
Hi ,
i want to add a user with partition , but partition was not visable under line
that partition has time schedule for ex : 10 am to 1 pm
but i can see under class of control > partiton and also for existing lines
For adding new line with same partition , so now i need to wait for the time 10 am to 1 pm or is their any way to add
kindly help me on this
karthik
1 ACCEPTED SOLUTION
Green
When you are viewing the line settings and you have many partitions there should be a
"find" button next to the partition drop down
The number od partitions to view in the drop down is controlled by
the system --> enterprise parameters ---> MAX LIST BOX ITEMS
Alex
Regards, Alex. Please rate useful posts.
Green
Alex
thanks a lot alex
276
