Urgent - PRI
Hello All,
Using PRI in the cisco router. Show inventory providing the T1/E1 info but Im not getting the T1/E1 info in show version. All the PRI cogitation are vanished even unable to reconfigure the PRI ie the router is not accepting the command "controller T10/0/0" in global config mode. I rebooted the router but no luck. Till yesterday it was working fine.
Version:c2900-universalk9-mz.SPA.151-3.T4.bin
Router : CISCO2911/K9
-Thanks
Urgent - PRI
Hi Murali,
What happens if you type sh diag
Perhaps you have to use another slot, example replace it to slot 2
Strange issue?
Urgent - PRI
Try to configure your T1E1 from bottom up...
network clock participate wic (X)
network clock select 1 T1 0/0/0
isdn switch type primary- XX
controller T1 0/0/0
framing XX
linecode XX
pri-group timeslote XXX
Hall of Fame Super Silver
Urgent - PRI
sh version does not show the PRI configuration, you need to run "sh run". As suggested run "sh diag" to see if the card is still recognizable in the proper slot and use "sh run" to see the current config.
HTH,
Chris
Hall of Fame Super Gold
Urgent - PRI
card type t1 0 0
VIP Purple
Urgent - PRI
Hi Murali,
What is the Card model u are using ?
please share the exact error message u get while configuring .
regds,
aman
Urgent - PRI
Thanks for all your assistance. Replaced the PRI card and the issue got fixed.
-M
216
