Community Member
urgent !!!! translation pattern
hi all,
i want to pass the call to local DN and International number so i have created translation pattern like below
internal 2000 PT-line partition
TP :      2000 PT-line kept called party as 1XXXXX
i thought call will pass to internal and international simultenously but call is going to TP with touching internal numbers ...
Please guide me how send a call both internal and international simultenously...
Karthik
Re: urgent !!!! translation pattern
to fork the call in the manner described you may want to look at the Mobile Connect (aka single number reach) feature.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_0_1/ccmfeat/fsmobmgr.html#wp1212169
Hth.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Just FYI, that behavior is expected. CUCM uses best match routing and only upon equally good matches the partition order in the CSS is used. From what you're saying the partition from TP is above the one from the DN in the CSS.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
163
