Urgent
Hi I need register a Third-Party SCCP Video Endpoints, specific the Sony PCS-1, which is compatible with the SCCP protocol. My doubt is How I can add it? I have the Cisco Call Manager Version 6.
Re: Urgent
A third party SCCP video endpoints is equivalent to that model of the cisco ip phone configuration?
Re: Urgent
You need to have the sccp firmware running on the PCS-1 and the license.
Then you need to install the coppackage on the callmanager and you can then select the PCS-1 as a device.
You can download the necesary firmware etc here : http://www.spireglobal.com/services-and-support/software-upgrades.asp#PCS1
Please rate the post if it was helpfull.
Kind Regards,
Jeroen
Re: Urgent
Hi jeroenhermans, thanks for answering my question. But I have another: for the SCCP Videoendpoints series Polycom VSX 5000, Polycom VSX 6000 and Polycom VSX 7000, where I can download the apropiate files to install the firmware in the Cisco Call Manager? Do you know where I can download these firmwares for these Polycom SCCP videoendpoints?
Thanks!!
Re: Urgent
165
