11-05-2014 12:33 PM - edited 03-17-2019 12:49 AM
CUCM 8.6.2a. IP Phones have configured some BLF Speed Dial.
I have been asked if possible to use the BLF Speed Dial only for monitoring busy line and not to make call. Is there a way?
Solved! Go to Solution.
11-05-2014 01:44 PM
Yes and No.
ON the BLF button (in phone configuration) itself you cannot assign a CSS or otherwise prevent call from being made with the BLF and just use it for presence status.
The only way to do it is prevent calls from being made from a particular BLF extension by means of partitions/CSS, in which case you cant call those number from the phones, period. Which is probably not desired either.
11-06-2014 08:48 AM
Unforunatellty there is no as BLF severs 2 purposes, line status presence and speed dial to the monitored DN. As far as I know there is no way to disable the latter.
Chris
11-05-2014 01:44 PM
Yes and No.
11-06-2014 06:07 AM
Hi Dennis
thanks for answer.
When BLF/SD is pressed, users hear the recorded voice from CUCM saying the call cannot be completed because configured partition/CSS does not allow it.
My question actually is: Is there way to prohibit calling at all? I searched in CUCM doc and I haven't found any hint.
11-06-2014 08:48 AM
Chris
11-07-2014 08:14 AM
Thanks for helping
Fulvio
11-07-2014 08:57 AM
no problem, let us know if you need anything further, otherwise please mark the question as answered.
