Silver
Use of Resource threshold command in GK
I`m been doing some reading and came across the comment
gateway
resource threshold high 70 low 60
From URL http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a0080093f67.shtml I understand it will check the resource available i.e E1`s  so if a GK has two choices to the same destinsation GW1 (5300-3)and GW2 (3640-3) each with an E1 based upon how busy, Resource availability etc it can "overflow" to GW2 . Based on the comments below the GK will route the call to the second GW 6789
  • gateway commends
gateway
  • gatekeeper commends
zone local cisco_2 cisco.com 172.16.13.42
zone remote cisco cisco.com 172.16.13.50 1719
zone prefix cisco 1*
zone prefix cisco_2 9* gw−priority 10 5300-3
zone prefix cisco_2 9* gw−priority 9 3640-3
gw−type−prefix 2#* default−technology
Would the GK not normally overflow anyway, based upon RAS messages to each GW and the priority setting on the Zone prefix of 9* or is the above a "better" way, more controlled manor ?
thanks
277
