10-21-2009 02:41 PM - edited 03-15-2019 08:11 PM
Customer wants to use their Verisign wildcard certificate for the Tomcat cert on the CUCM servers, will this work?
Solved! Go to Solution.
10-21-2009 04:38 PM
Wild card certificate is not supported by CUCM (or CER, or CUPS, or CUMA).
But they do support "alternative name" in certificates.
Michael
10-21-2009 04:38 PM
Michael
10-21-2009 04:43 PM
Great, thanks. Great book on CUPS too! :)
11-16-2009 10:59 AM
HTLuo,
I came across your response while trying to find out if Unity Connection supported wildcard certs. When I try to load one, I get name on certificate does not match server name. unitycnx.sample.com does not match *.sample.com.
Since our Cisco remote access VPN supports wildcard masks, I am not sure why the Unified Communications equipment does not. I would like to submit this to Cisco as a feature request. Can you think of a reason why Cisco would not or can not add this feature?
I also enjoyed your CUPS book! Do you have any plans on writing a basic book for UCCX? This is a complicated subject, but I'm sure your straightforward writing style would allow anyone to come up to speed on the basics.
Mark
11-16-2009 02:11 PM
I really can't find a reason why wildcard cert is not supported. It's so common in the field. I would recommend you submit a feature request. Maybe the development team is just waiting for enough votes to proceed. :)
Regarding UCCX, I wish I had written the book while I'm in UCCX team. It would have been much more easier. UCCX 8 is supposed to be on Linux platform. I guess I would write a book then (if my boss can spare me some time) :)
Michael
12-08-2010 06:09 AM
Having a customer asking for that as well,
another vote from me for suporting wildcard certificates !
Another thing is:
I did not yet find a way to import and use completely externaly generated certs
(including their public& private keys) and use them i.e. as
TLS Server Cert for the management tomcat server.
The only thing I found in the WebGUI was generating a CSR...
Did I miss something ?
Frank
Sorry, but I am often dealing with Cisco ASA firewalls and IOS Routers,
where this has been possible for years now ..
