You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our beta test area to get started.
User are not able to make conference call
Hi All
users from one site are not able to make the coneference calls. Prior to this users were able to make conference calls.
We have configured MGCP configuration. When we shift the traffic to PSTN. Conference calls works fine. As we shift the traffic back to WAN Link conference calls are dropping.
We had done with the changes of  Conference bridge order but no positive result found.
We tested (When the traffic is going through WAN Link)
Although the conference bridge appeared to join the 4 calls the Mobile phone rtps streams were not active
Each of the tests involved 2 Ip Phones and 2 Mobile phones.
When running the conference via WAN Link the mobile phones lost their RTP streams and no voice either way could be heard, however the IP phones were actively running RTP sessions and could hear voice both ways
PFA For the Logs during the test Window
Thanks For Help
  • IP Telephony
Are you using hardware conferencing resources? If not, verify that you have transcoding resources.
Yosh
HTH Regards, Yosh
Hi Yosh
Thanks for Replying
Yes, we are using the Hardware Conference Resources.
Chaman
Are you using G.729 for the WAN? Verify that the users MRGL has the hardware conferencing resources, on the top of the MRG list.
Yosh
HTH Regards, Yosh
yes we have G.729 for the WAN
And have hardware conference resources on the top of MRGL
Chaman
Have you verified routing between the WAN, firewall, phones and your hardware resource router?
Yosh
HTH Regards, Yosh
Hi Yosh
I checked the routing as well as hardware resources. But didnt find any error.
Chaman
Do you have a firewall between the WAN. If so, verify with the security team that they are not seeing any blocks in traffic, during a test call.
Yosh
HTH Regards, Yosh
We dont have any firewall.
Chaman
203
