User authentication to make STD/ISD call
somnath21
We are using Cisco call manger 4.2.Now we want to configure authentication for indivisual user before making STD and ISD call.I have allocated those users under calling search space group 2 which is for STD/ISD.Now how to authenticate per user before making call.Please guide in this matter..
somnath
5 Replies 5
Marwan ALshawi
as u mentioned u have grouped them in a CSS
now creat a partion for example call it p1
includ this partion in the usres group in ur CSS
then make a route pattren to the desired number or numbers and put it in partion p1
now only those users in that CSS with partion p1 inout example will have access on the route pattren
now u can configure authentication for them as the following:
Creating Forced Authorization Codes
It works this way: when a call is placed that requires an authorization code, a double beep is heard that alerts the caller to enter the code. After the code is entered, the call is completed.
Enabling FACs requires that FACs exist and that the route patterns that are to be restricted are configured to require an FAC. The following steps show how to accomplish both of these tasks.
Create a Forced Authorization Code
Step 1. From within CCMAdmin, select Feature>Forced Authorization Code.
Step 2. Click the Add a New Forced Authorization Code link
Step 3. In the Authorization Code Name field, enter a name for this code. Choose a name that helps identify the code. This name displays in authorization code reports that can be produced.
Step 4. In the Authorization Code field, enter a numeric code. This is the code a caller will have to enter to place calls that require authorization.
Step 5. In the Authorization Level field, enter a numeric value between 0 and 255. This value determines the authorization level of this code. In order for the code to allow a call, the value in this field must be equal to or greater than the value assigned to the pattern.
Step 6. Click the Insert button to add this code. After the code is created, the status line displays "Insert completed."
Assign a Forced Authorization Code to a Route Pattern
Step 1. From within CCMAdmin, select Route Plan>Route/Hunt>Route Pattern.
Step 2. Enter search criteria in the search field to limit the results and click the Find button.
Step 3. From the list that displays, select the route pattern to which you wish to add an FAC.
Step 4. Check the Require Forced Authorization Code box and enter a numeric value in the Authorization Level field. This value is used to determine which FACs have the right to use this pattern. An FAC must have a value equal to or greater than this value in order to be granted access
Step 5. Click the Update button to apply FAC to this pattern.
Step 6. Repeat these steps for all other route patterns on which you wish to enable FAC.
OR UCAN USE Create a Client Matter Code
Step 1. From within CCMAdmin, select Feature>Client Matter Code.
Step 2. Click the Add a New Client Matter Code link.
Step 3. In the Client Matter Code field, enter the desired code
Step 4. In the Description field, enter a description that identifies the client or project with which this code is associated.
Step 5. Click the Insert button to add this code. After the code is created, the status line displays "Insert completed."
Assign a Client Matter Code to a Route Pattern
Step 3. From the list that displays, select the route pattern to which you wish to add a CMC.
Step 4. Check the Require Client Matter Code box
Step 5. Click the Update button to apply the CMC requirement to this pattern.
Step 6. Repeat these steps for all other route patterns on which you wish to require CMC.
source is Cisco press
and male sure that the phones u wan them to to put a code are in a CSS that contains the partion of the route pattren with authentication
good luck
please, if helpful Rate
Thanks!
But suppose I want to give STD facility to 3 users only.In the above process all the 3 user will get the same key to activate the call.How to give 3 different key to 3 users.So that individual can call STD with their own key only.Please guide..
Is there any process to lock the ip phone with security code like analog phone.
som
in this case use client matter code as mentioned above
creat three codes give each user a code
Creating CMC Codes
Complete the following steps to add CMCs in Cisco CallManager Administration:
Step 1. In Cisco CallManager Administration, choose Feature > Client Matter Code.
Step 2. In the upper-right corner of the window, click the Add a New Client Matter Code link.
Step 3. In the Client Matter Code field, enter a unique code of no more than 16 digits that users will enter when placing a call
Step 4. In the Description field, enter a name of no more than 50 characters. This optional field associates a client code with a client.
Step 5. Click Insert
Enabling Route Patterns for CMC
Complete the following steps to enable route patterns for FAC and CMC:
Step 1. In Cisco CallManager Administration, choose Route Plan > Route/Hunt > Route Pattern.
Step 2. Open the properties window for the route pattern you want to modify.
Step 3. If you are configuring the route pattern for CMC, check the Require Client Matter Code check box
good luck
if helpful Rate
now the question is if any user use any other phone to make STD call by using his own CCM, how to get/identify that one?
Reagrds,
som
How to get the authorization code reports ?
