User Busy Release Message from H323 GW to CUCM 6.1
I have a CallManager Cluster (ver 6.1) and a voice gateway (Cisco  3945). All my other gateways are running mgcp but this one cant as CUCM  6.1 does not support 3945 using mgcp.
Routing to and from a site using a 3945 works 100% using h323. Only  problem is that when you’re calling a mobile number, and press decline  on the mobile, the Cisco IP phones is still getting a ringback tone for a  couple of second and finally gets a user busy tone and message on the  screen.
Where can I configure this?
I’ve ran traces on the gateway and I see a User Busy message but CallManager does not clear the call:
025993: Nov 22 14:43:15.722: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0xA771
Cause i = 0×8091 – User busy
Please advise
1 REPLY
Never mind. Global config command: voice call disc-pi-off solved the problem.
169
