11-20-2007 09:00 AM - edited 03-15-2019 07:20 AM
Not sure what would cause this, but I am open to suggestions! Would deleting the device and re creating it work?
11-20-2007 10:00 AM
Hi Chet,
It sounds like the CSS (Calling Search Space) setting on the phone is set up for a restrictive level which cannot make calls to the remote extensions. The easiest way to test this is to find a working phone and match the CSS Settings.
Hope this helps!
Rob
11-20-2007 10:52 AM
Check your dial patters for the remote extensions... If there are seperate lists for them try resetting the route list.
Are these remote extensions all in the same cluster?
11-20-2007 11:25 AM
Mid, Where do I Check my dial patters for the remote extensions? I can tell you that the user can dial some extensions at this remote location, but not others.
Rob ,I looked at the CSS settings and they seam normal.
Whoops, I just changed her CSS settings to International and it fixed the problem, only thing is others can call remote extensions without this setting?
Woops again! I did not dig deep enough when checking the Directory Number Settings / CSS settings. Thanks guys problem solved
