Community Member
user is engaged in another call
Hi all
Can you please tell me if the following scenario is possible and if possible how can it be done (i am using CCME and CUE):
All dns are configured as dual lines.
User A and User B are having a telephone conversation, is it possible to give a "User is engaged in another call" message or any other message for User C when he tries to call User A.
its like call waiting in cellular systems
Thanks a lot
Laith
Hall of Fame Super Gold
Re: user is engaged in another call
Sure. What do you want exactly to happen, a message then disconnect, or the possibility of wait on the line ?
Community Member
Hi bevilacqua
Can you please give me the message and wait on the line.
Thanks a lot
This is a script that I wrote for "wait on the line", the service is actually called camp-on:
http://pbevila.fastmail.fm/public/camp-on/
For disconnect, the script would be a 10-lines one that plays the messages and disconnects.
For these you need to configure "huntstop channel" and "call-forward busy" under ephone-dn or ephone-dn-template.
When calling from an ip phone you can also use the 'callback' softkey to be notified when the desired extension is available.
hope this helps, please rate post if it does!
Community Member
Hi paolo
Sorry for my late response, please excuse me i am new to Cisco IP Telephony, do i need to install IVR and how? and what about the "param prompt-interval " configuration parameters do i need to configure them on the router or in the script?
Thanks a lot for your help
TCL/IVR is embedded in voice IOS, you don't need to install anything.
Changing the script parameters is optional, if you want to change them, configure in the router under application, service camp-on.
Thanks for the nice rating and good luck!
113
