Community Member
User Locale - Chinese
Hi Cisco Fam,
I have spent quite a bit of time looking for the chinese user locale file for CUCM 7.  What is wrong with my search that all I am finding is CME related files?  If I'm not mistaken, I should be looking for something similar to cm-locale-zh_CN-7.0.1.1000-1.cop.sgn .  A search on that on Cisco brings 0 results.  Google brings a few Chinese websites that offer a download that CUCM didn't accept.  Does anyone have helpful search hints on Cisco that would bring this up?
Thanks in advance!
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: User Locale - Chinese
Hi Keith,
Here is the path
Cisco> Support>Tools and Resources> Software Downloads>  Voice and Unified Communications > IP Telephony > Call Control> Cisco Unified Communications  Manager Version 7.0 > Unified Communications  Manager/CallManager Locale Installer > 7.0(1.3000-1) > cm-locale-zh_CN-7.0.1.3000-1.cop.sgn >
Cheers!
Rob
Hi Keith,
Here is the path
Cheers!
Rob
Super Bronze
Go to :
www.cisco.com/go/software
Log in.
In the search box on the right, if you know the filename you are interested in, then put in the leading characters. I tried:
cm-locale-zh_CN
And found lots of relevant stuff.
The other way is go to the URL above, click 'Voice and Unified Communications' and then browse to your particular product/version in the next page.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
313
