Community Member
User Seach Restriction - Corporate Directory
Hi All,
Good Morning !!!
My Customer has ask me the following requirement can be implemented in CUCM & LDAP:
Onely one CUCM (8.5) Cluster integrated with LDAP  (Windows). The same cluster is being used for different Clients. The requirement is that, can be possible to configure CUCM or LDAP to show all users in same client while searching by using Corporate Directory. User should not be able to see other company Phone list while searching from his/her phone.
I will appreciate your quick response.
Nirmal
VIP Super Bronze
No. The Corporate Directory built into CUCM will show all End User objects in the search results. You can look at third-party solutions or write your own; the XML SDK is open.
Please remember to rate helpful responses and identify helpful or correct answers.
Community Member
Hi Nirmal
You can check out Parsec Telesystems ADVANCED DIRECTORY SEARCH Cisco IPT Application.
It should fulfill your requirement.
Pranjol Saikia
pranjol.s@parsec-tech.com
250
