user table
within cucm 4.x in a scenario where the cucm is integrated to AD is there a way to get at the user information within sql and if so where is it located?
Looking to extract this information.
thanks,
paul.
Re: user table
User info has never been stored in SQL, SQL is exclusively used for CUCM information (only users it holds are the AC users you log into the app)
User information is in the User Directory, whether you use DCD or AD.
java
if this helps, please rate
java
www.cisco.com/go/pdi
Re: user table
any way you know to programatically get at the info?
Re: user table
From CCM itself the only way is to use BAT to export users, it will connect to the directory and extract the info.
java
java
125
