Users does not hear answering machines and PSTN messages
We are experiencing issues when we place a call to the PSTN and it is redirected to a answering machine, for example if I place a call to my cell phone and it is powered off normally it will be  answered by the voice mail of my celular company, but in this case whe have two strange behaviors:
1.- the call keeps ringing like my cell phone were available.
2.- the call is connected but we are experiencing something like one way audio, we cannot hear audio from the voicemail, but checking my voice mail on my cell phone I realized that I am able to leave a message.
This two issues occours randomly and for both home answering machines and cell phones voicemails, with regular calls we have no problems.
we have:
     CUCM 9.1
     GW 3900 - 15.1 (4) M7
The GW is connected with the CUCM via SIP, and with the PSTN with E1 R2.
Phone > CUCM > SIP > Gateway > E1 R2 > PSTN
Here is part of the configuration that I think could be relevant:
voice call convert-discpi-to-prog
voice service voip
no ip address trusted authenticate
allow-connections sip to sip
signaling forward unconditional
sip
  bind control source-interface Loopback0
  bind media source-interface Loopback0
  rel1xx disable
  min-se 360 session-expires 360
  header-passing
voice rtp send-recv
controller E1 3/1
framing NO-CRC4
line-termination 75-ohm
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 0
   country telmex
   release-guard-time 2
   disconnect-tone
   category 2
   answer-signal group-b 1
   ani-digits min 4 max 20
   answer-guard-time 500
   timer interdigit incoming 1000
   groupa-callerid-end
   dtmf timer inter-digit 250
description E1 para PSTN
voice-port 3/1:0
cptone MX
dial-peer voice 401 pots
  description ** LLAMADAS A CELULAR LOCAL  y LD**
  preference 1
  destination-pattern 9044..........
  port 3/1:0
  forward-digits 13
  no register e164
I hope you can help me.
Regards.
Hi.
Can you please post both the output of a debug ccsip message and a deb isdnq931 while calling to a switched off mobile phone?
Thanks in advance.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Re: Users does not hear answering machines and PSTN messages
Hi Carlo
I posted the output of a debug ccsip messages.
We do 2 calls
1st At 10:27 and the result was continuous ringing.
called number:90445563185547
calling number: 7038
2nd At 10:30 and the result was one way audio.
Regards.
217
