users using Extension Mobility takes too long to login
Extension mobility takes long time (2 to 3 minutes) to login and logout only for 7941 phones after cucm upgraded (refresh upgrade) to 7.1.5
call manager cluster with 1 publisher and 1 subscriber
I have performed the following troubleshooting still not working,
1.upgraded phone firmware to SCCP41.9-3-1SR4-1S
2. looked for any memory leak and did utils diagnose test
3. created a new service url to Subscriber and tried.
4.  rebooted the cluster
please see the logs from the phone as below
1108: NOT 17:59:05.866789 JVM: Startup Module Loader|cip.cfg.k:? - ConfigManager updateCTL() rc=2 retryCount=0
1109: WRN 17:59:05.871557 SECD: WARN:getTLInfoFromFile: ** phone has no TL file /flash0/sec/ctl//CTLFile.tlv
1110: WRN 17:59:05.872961 SECD: WARN:getTLInfoFromFile: ** phone has no TL file /flash0/sec/ctl//ITLFile.tlv
1111: NOT 17:59:05.884184 JVM: Startup Module Loader|cip.cfg.t:? - Requesting CONFIG file from TFTP Service(1)
1112: ERR 17:59:05.889119 JVM: tftpClient SEP00215554E915.cnf.xml /usr/ram/SEP00215554E915.cnf.xml 550001 1
1113: NOT 17:59:05.895029 xxtpClient: xxtp request rcv'd from /usr/tmp/tftp, srcFile = SEP00215554E915.cnf.xml, dstFile = /usr/ram/SEP00215554E915.cnf.xml max size = 550001
1114: NOT 17:59:05.912720 xxtpClient: auth server - tftpList[0] = ::ffff:10.154.133.31
1115: NOT 17:59:05.913615 xxtpClient: look up server - 0
1116: WRN 17:59:05.916565 SECD: WARN:lookupCTL: ** no CTL, assume TFTP NONSECURE
1117: NOT 17:59:05.920791 xxtpClient: secVal = 0xa
1118: NOT 17:59:05.921830 xxtpClient: ::ffff:10.154.133.31 is a NONsecure server
1119: NOT 17:59:05.922735 xxtpClient: temp retval = SRVR_NONSECURE, keep looking
1120: NOT 17:59:05.923545 xxtpClient: retval = 10
1121: NOT 17:59:05.924369 xxtpClient: Secure file requested
1122: NOT 17:59:05.925156 xxtpClient: Non secure file approved -- SEP00215554E915.cnf.xml
1123: NOT 17:59:05.965712 HTTPCL: downdload will be limited to 537 KB
1124: ERR 17:59:33.245953 CDP-D: ----- cdpSend ----- Phone's MAC address is SEP00215554E915
1125: ERR 17:59:36.501652 HTTPCL: connect() failed
1126: NOT 17:59:36.513625 SYSMSG: pid 7 (/sbin/httpcl) Normal Exit, status = 102
1127: INF 17:59:36.513699 runtime = 30.580 secs
Barry
1 REPLY
OK so your CM is 7.1.5?Have
Have you downgraded the FW of the phones and see if it still takes so long to login?
I have upgraded from ver 4 to ver 9 and had to follow a upgrade path with the FW as well to make sure the phones don't reset everytime you login or out and also did take a long time.
Make sure on the CM it shows the current FW as the active load and not unknown.
My advise will be to downgrade 2 or 3 versions and if the problem is taken care of upgrade 1 version at a time.
Voice CCIE #37771
297
