Bronze
Using 7960G with CME 7.1
Is it possible to use the 7960G IP phone with CME 7.1?
I have a new 2851 Voice bundle and I can't get the phone to download a firmware/config.
Thanks in advance,
--Brandon
Bronze
Re: Using 7960G with CME 7.1
The 7960G is supported:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme71spc.htm
SIP Loads:
P0S3-08-6-02.loads*
P0S3-08-6-02.sb2
P0S3-08-6-02.sbn
SCCP Loads:
P00308000500.loads*
P00308000500.sb2
P00308000500.sbn
Make sure you have downloaded and installed those files on your flash:. You will also need to have file in your TFTP statements within the router config.
Bronze
Thanks. I was able finally able to get it to load P00308010100, but now i'm strugglign with the config -- it keeps saying it can't find XMLDefault.cnf.xml
Hall of Fame Super Gold
You have not entered the mac address correctly under ephone then.
430
