Community Member
Using BAT to change the DID range
My office is getting relocated. In this case I have changes in the DID range execept the last 2 digits. How can we change DID range using BAT Tool for the extentions. I have about 200 phones.
Faizal
1 REPLY
Green
Re: Using BAT to change the DID range
Hi Faizal,
Normally for changing Directory numbers you need to delete the DN and then re-assign them
I normally do Export all details, delete and then re-import with the information I obtained from Export.
129
