Using BAT
jaime.garcia
I need to setup 75 7962 IP Phones.  What is the best procedure on doing so using BAT.  I have never used the tool.  All phones need the same config except the DN.  We have a block a 75 DIDs.  Any help would be appreciated.
Jaime
Jaime Valencia
Download the bat.xlt and use it to create a template for those phones.
This is the link to the tool help and how to use it for all the procedures.
Cisco Unified Communications Manager Bulk  Administration Guide, Release 8.0(2)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/8_0_2/bat-802-cm.html
All the related elements you'll use need to be already configured in CUCM (partitions, device pools, MRGLs, etc)
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
