02-14-2012 08:24 PM - edited 03-16-2019 09:36 AM
Currently I've a couple of c2811 and c3825 running IOS 12.4....Can I use it to run CME 8-9?
I understand CME 8-9 need IOS 15.0. Can I install IOS 15 to this c28xx and c38xx? I thought IOS 15.0 need license key to activate the voice feature...I'm just using it for my CCNA lab practice do I still need to pay $$$$ for IOS license key?
Solved! Go to Solution.
02-14-2012 08:34 PM
CME 8.5 is supported in above hardware
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme85spc.htm.html
Ronak patel
02-14-2012 08:38 PM
Absolutely, 15.X train is supported on ISR G1 routers (28XX, 38XX). The UC license is enforced on the G2 platforms (29XX).
Chris
02-14-2012 09:01 PM
If you have valid contract and purchased the CME licenses you are entitled to the upgrade. The 28XX does not enforce the licenses though, so no licenses need to be applied.
Chris
02-14-2012 10:00 PM
You have to load related IOS and related filed on router to use CME 8.5 in ISR G1. Download IOS , GUI files from cisco.com and load them on to router.
Regadrs
Ronak Patel
02-15-2012 05:39 AM
Reference the CME Admin Guide:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeinstl.html
HTH, Please rate all useful posts!
Chris
02-14-2012 08:34 PM
Ronak patel
02-14-2012 08:38 PM
Chris
02-14-2012 08:58 PM
Hi Chris,
Don't quite understand the sentence...Does it mean I can load IOS 15.x into ISR G1 and I don't license key to activate it?
Whereas ISR G2 need to purchase a license key?
Choy
02-14-2012 09:01 PM
Chris
02-14-2012 09:05 PM
Thanks..
Is there any step-step doc/URL that teaches us how to install CME into a ISR G1 router?
02-14-2012 10:00 PM
Regadrs
Ronak Patel
02-15-2012 05:39 AM
Chris
