Using c2811 to CME 8-9?
Currently I've a couple of c2811 and c3825 running IOS 12.4....Can I use it to run CME 8-9?
I understand CME 8-9 need IOS 15.0. Can I install IOS 15 to this c28xx and c38xx? I thought IOS 15.0 need license key to activate the voice feature...I'm just using it for my CCNA lab practice do I still need to pay $$$$ for IOS license key?
5 ACCEPTED SOLUTIONS
Blue
CME 8.5 is supported in above hardware
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme85spc.htm.html
Ronak patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hall of Fame Super Silver
Absolutely, 15.X train is supported on ISR G1 routers (28XX, 38XX).  The UC license is enforced on the G2 platforms (29XX).
Chris
Re: Using c2811 to CME 8-9?
If you have valid contract and purchased the CME licenses you are entitled to the upgrade. The 28XX does not enforce the licenses though, so no licenses need to be applied.
Chris
Blue
You have to load related IOS and related filed on router to use CME 8.5 in ISR G1. Download IOS , GUI files from cisco.com  and load them on to router.
Regadrs
Ronak Patel
Reference the CME Admin Guide:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeinstl.html
HTH, Please rate all useful posts!
Chris
Blue
Ronak patel
Chris
Hi Chris,
Don't quite understand the sentence...Does it mean I can load IOS 15.x into ISR G1 and I don't license key to activate it?
Whereas ISR G2 need to purchase a license key?
Choy
Chris
Thanks..
Is there any step-step doc/URL that teaches us how to install CME into a ISR G1 router?
Blue
Regadrs
Ronak Patel
Chris
1362
