Using Click to Call and wanted to strip local DNs prefixes to stay on-net
Hello all,
I am using click to call.  The AD credentials are using a 10 digit number.  I wanted to strip the area code and prefix and only call the dial the last 4 digits of internal numbers.  Any suggestions on the best way to do this?  Any input is greatly appreciated.
Matt
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Build translation patterns or called transformation patterns in CUCM, or if this is a system wide setting you can build application dial rules.
HTH,
Chris
HTH,
Chris
So for an application rule I would use a range of 212-555-2000-2999
Number begins with 2125552
Number of Digits: 10
Total Digits to be removed: 6
Prefix with Pattern: none
Yes.  Make sure you apply the application dial rules to your devices, it's not enough to just define it on CUCM, you need to run a cop file and restart the devices.
HTH,
Chris
Thanks.  I am not too familiar with cop files.  The application dial rules I created earlier seem to be working for outbound calling without doing anything else.
202
