Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Using CUE with CM 7.0 (ccm-manager credentials hidden)
Hi all,
I have a Central Office with Call Manager 7.1 and a branch with CUE 7.0.4. In my Branch have the following:
se-10-122-217-10# show ccn status ccm-manager
JTAPI Subsystem is not registered with any Call Manager
I think is because i need to configure
ccn subsystem jtapi
ctiport 8601 8602 8603 8604
ccm-manager address 10.122.140.100
ccm-manager credentials hidden XXXX
end subsystem
Can somebody hel me using the command ccm-manager credentials hidden XXXX
XXXX= username + password jtapi? encrypted?
What can i do to encrypted this, which tool can i use?
Best Regards
1 REPLY
Re: Using CUE with CM 7.0 (ccm-manager credentials hidden)
In the CUE GUI, go to Configure > Callmanager. You should be able to enter the JTAPI username/password in an unencrypted format from here.
Hope this helps.
Brandon
342
