11-18-2010 10:21 AM - edited 03-16-2019 02:00 AM
I wish to upgrade current 4.2(3) cluster to 7.1(5b). I am assuming i would run DMA version 7.1.5 on the 4.2(3) publisher. When running DMA on the PUB is there downtime associated or will call processing still be available? As all devices right now are registered to the PUB as I have removed the subscribers to upgrade offline. Thanks in advance.
Solved! Go to Solution.
11-18-2010 11:50 AM
Hi Johnny,
You'll want to run DMA after hours as it may consume some large CPU
resources. It also requires a reboot
Cheers!
Rob
11-18-2010 11:50 AM
Hi Johnny,
Cheers!
Rob
