Community Member
using FXS ports on 2nd VIC card
I have a UC500 with two 4-port FXS cards. The 4 ports on the first card were automatically setup and ephones were configured using the MAC address of the first card. Now I want to use the FXS ports on the 2nd card but I don't know how to get the MAC addresses for the second card. When I do "sho stcapp device summ" I only see the first four ports. What do I need to do here?
Diego
Re: using FXS ports on 2nd VIC card
with FXS ports u dont need any mac address and even done need ephon !!!!
can u post ur config
fxs for analog phones
if u have fxs port 0/0/0 connected to analog phone and u want to give it ext. number as 333
u need pots dial-peer as following
dial-peer voice 9 pots
destination-pattren 333
port 0/0/0
good luck
Community Member
I understand that it will work. However, I want to use the DN and ephone for consistency with the other analog devices. You also get internal caller-id and the extensions are logged in the directory.
Diego
173
