Using kron scheduler to backup a CME running config file
I would like to use the kron command to schedule a backup of a CME configuration to an FTP server. How do I specify the host FTP server? I'm using the following link as a reference:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_tech_note09186a008020260d.shtml
Backup Configuration to a TFTP Server:
This example is to save the running config to a TFTP server (10.1.1.1) every Sunday at 23:00:
Router(config)#kron policy-list Backup
Router(config-kron-policy)#cli show run | redirect
tftp://10.1.1.1/test.cfg
Router(config-kron-policy)#exit
Router(config)#kron occurrence Backup at 23:00 Sun recurring
Router(config-kron-occurrence)#policy-list Backup
Everyone's tags (1)
1 REPLY
Re: Using kron scheduler to backup a CME running config file
i think if you use EEM will be easier
try the follwoing:
event manager applet backup
event timer cron name "sundays" cron-entry " 0 0 * * 0"  ---trigger script midnight once a week on Sunday
action 1.0 cli command "enable"
action 2.0 cli command "config t"
action 3.0 cli command "file prompt quiet"
action 4.0 cli command "end"
action 5.0 cli command "copy running tftp://serverIP"   use normal CLI copmmands
action 6.0 cli command "config t"
action 7.0 cli command "no file prompt quiet"
action 8.0 cli command "end"
if you still have issues i would recomnd you to open this discussion under network managment section
good luck
if helpful Rate
1417
