10-18-2013 06:26 AM - edited 03-16-2019 07:58 PM
Hi All,
A quick one !
Wanted to confirm if the below mentioned documentation regarding the -- Live Record Capability with Unity Version 4.0(5) and greater -- does this feature -- still exists and is there a valid documentation for that particular current version.
Would appreciate a quick confirmation on the same .
Whatever level you reach.... getting better never stops -- Sachin Tendulkar
Solved! Go to Solution.
10-18-2013 06:37 AM
Hi Abhishek,
Hope all is well
Yes, Live Record is still fully supported;
Cheers!
Rob
"Why do the best things always disappear "
- The Band
10-18-2013 06:37 AM
Hi Abhishek,
Hope all is well
Cheers!
Rob
- The Band
10-18-2013 07:29 AM
Hi Rob,
You are the man , Rob -- you may have a grin reading this -- but I get an uncanny feel -- that you would be the one to help me out -- thanks for always showing the way to the novices
Whatever level you reach getting better never stops -- Sachin Tendulkar
10-18-2013 08:31 AM
Hi Abhishek,
You are always welcome my friend! I think I just happened
to be the first one to read your post
Cheers!
Rob
- The Band
