09-21-2007 08:20 AM - edited 03-14-2019 11:40 PM
We have setup our voip dial-peers to use the loopback address with the 'voice-class source" command. Thats ok for one direction. Now how do we setup the receiving end to use its loopback address. Is there some command to put on the dial-peer pots entry to force the use of the loopback address on the return packets.
PS In case you have not noticed I know next to nothing about voice, so please forgive if this is an easy, straight forward question.
09-23-2007 09:12 AM
These commands on your loopback interface will source all H323 traffic from the loopback. You do not need the dial-peer voice-class command.
h323-gateway voip interface
h323-gateway voip bind srcaddr x.x.x.x
HTH.
09-24-2007 12:22 PM
There is no h323 gateway explisitly defined anywhere in the config.
09-24-2007 02:24 PM
For H323, you would use the above config. For SIP, there are equivalent commands.
09-27-2007 10:29 AM
Thanks for the replies. I do not know enough to know whether I am using H.323 or sip. Will try the suggestions.
