Using NME-CUE : Can I still use the CUEEditor
Now the NM-CUE is on "end of sale".
Can I still use the CUEEditor for programing my IVR?
What is the difference between CUEEditor and the CUEScript Editor?
1 REPLY
Hall of Fame Super Red
Re: Using NME-CUE : Can I still use the CUEEditor
Hi Solo,
Yes, you can use the CUE Editor with the NM-CUE. The difference the CUE Editor and CUE Script Editor is in name only. They are interchangeable.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_1/release/notes/rncue31.html
Hope this helps!
Rob
102
