Using second codec in CUCM 7.1 Cluster
Hi all,
I'm having an issue where i'm tyring to setup different codecs for a group of phones where bandwidth is at a premium. I'm trying to convert them over to use g729, but am having some issues. Our main codec is g711u. I created a new region and device pool to assign the phones to. Inbound calling appears to work for the phone I am testing with, as does inter-extension dialing, but outbound calling does not work. I assume the issue is somewhere on our PRI gateway, since the call seems to fail somewhere when the codec is trying to be negotiated. The call signal does come through, but when the call is answered it goes to a fast busy immediately. I can post or give any configs of value. I would really appreciate any help as I have kinda hit a wall.
Ian Mock
Hall of Fame Super Silver
What protocol are you using to control the GW?
If H323 or SIP make sure you changed the codec approriately on the dial-peers or codec class.
HTH,
Chris
I'm not sure on the protocol. In the CUCM config it says "Digital Access PRI".
Forgive my ignorance, but I inherited this CUCM from an engineer who left the company. I haven't had much training on it's configuration, but I do know where to look to find things.
When you say changed the codec appropriately, do you mean within CUCM or on the PRI gateway?
Ian
Besides changing the codec in CUCM for SIP/H323 GWs you need to define the codec on the dial peer configurtion on the gateway itself, can you post a screen shot of your Gateway page from CUCM?
Chris
I hope this helps:
Here is a cleaned config of the primary PRI gateway:
version 12.4
hostname NET-SLCORP-TCR01
boot-start-marker
boot bootstrap flash c2800nm-spservicesk9-mz.124-24.t3.bin
boot system flash:c2800nm-spservicesk9-mz.124-24.t3.bin
boot-end-marker
card type t1 0 0
logging message-counter syslog
aaa new-model
aaa authorization config-commands
aaa authorization exec default local
aaa session-id common
network-clock-participate wic 0
network-clock-select 1 T1 0/0/0
dot11 syslog
ip source-route
ip cef
no ipv6 cef
isdn switch-type primary-ni
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
voice class codec 2
codec preference 1 g711alaw
codec preference 2 g711ulaw
voice-card 0
archive
log config
  hidekeys
controller T1 0/0/0
cablelength long 0db
pri-group timeslots 1-24 service mgcp
description 80001/T1ZF
controller T1 0/0/1
shutdown
interface FastEthernet0/0
ip address 10.10.10.21 255.255.255.0
duplex full
speed auto
no mop enabled
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn supp-service name calling
isdn bind-l3 ccm-manager
no cdp enable
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.10.10.1
ip http server
no ip http secure-server
logging 10.10.1.50
snmp-server community slpub RO
snmp-server community slpriv RW
snmp-server contact WUG
control-plane
voice-port 0/0/0:23
echo-cancel coverage 64
ccm-manager redundant-host 10.10.2.4
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.10.2.5
ccm-manager config
mgcp
mgcp call-agent 10.10.2.5 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp default-package fxr-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax-relay ans-disable
mgcp profile default
sccp local FastEthernet0/0
sccp ccm 10.10.2.5 identifier 2 version 7.0
sccp ccm 10.10.2.4 identifier 1 version 7.0
sccp
sccp ccm group 1
bind interface FastEthernet0/0
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 1 register MTP_TCVR01
dspfarm profile 1 mtp
codec g711ulaw
codec pass-through
maximum sessions software 20
associate application SCCP
dspfarm profile 2 mtp
codec g711ulaw
codec pass-through
shutdown
dial-peer voice 678 voip
description SR140 Outbound
destination-pattern 9[2-9]..[2-9]......
session protocol sipv2
session target ipv4:10.10.2.5
session transport udp
codec g711ulaw
privilege exec level 3 show startup-config
privilege exec level 3 show running-config
line con 0
exec-timeout 15 0
logging synchronous level 5
line aux 0
line vty 0 4
exec-timeout 15 0
privilege level 15
line vty 5 15
exec-timeout 15 0
privilege level 15
scheduler allocate 20000 1000
end
10.10.2.4 is the pub
10.10.2.5 is the sub
OK, so you are using MGCP, all the configuration for the PRI with MGCP is defined on CallManager.
Look at the PRI port configuration, take a note of the device pool assigned
Find that device pool and see what region it is using
Look at the region configuration and find out what codec is used between this region and the phone you are calling from/to
Chris
It is assigned to the one that uses the default g711 codec. Is there not a way to have it use more than one?
It is more than one, it is anything that is lower than the one you selected, but when the call negotiates it will always attempt to negotiate the highest possible codec defined, in your case G711.  So, with G711 defined and both devices supporting G711 it will always use G711. If you need to force it to something lower i.e. G729 you need to adjust one region.
Chris
I think I did that already. I defined a new region called "Default Low Bandwidth" and set it to use g729. I then defined a new device pool called "Default Low Bandwidth" and added the new region to it. I then added the phones to the new device pool. Stats on the phone show that it's using g729 and I can hear a slight difference in voice quality.
So how would I be able to force the gateway to use g729 if it's already set to use the device pool that has g711 defined?
You force it by assigning proper DP to the GW, so if the intent is to force calls from site A to use g729 when going out of this GW then you need to device a region that is using G729 between it and the one phones are using, then assign DP with that region to the GW. if all local phones need to still use G711 then make sure this region is using G711 between this site's region. Basically you are creating a matrix of whio is going to use what codec.
HTH, please rate all useful posts!
Chris
805
