Bronze
Using Trunk Groups for Incoming Calls from PSTN
I currently have an H.323 gateway with one ISDN PRI to the PSTN. It uses trunk-groups for outbound calls that works just fine, but I'll be adding 2 more PRIs and was I could use the trunk-groups for incoming calls as well in order to simplify the config. I haven't seen any examples of doing this yet:
Current config:
controller T1 0/1/0
framing esf
linecode b8zs
pri-group timeslots 1-24
description PRI PSTN
interface Serial0/1/0:23
no ip address
isdn switch-type primary-ni
isdn incoming-voice voice
trunk-group PSTN
no cdp enable
voice-port 0/1/0:23
dial-peer voice 1 pots
incoming called-number ....
direct-inward-dial
port 0/1/0:23
Proposed config:
controller T1 0/1/0
framing esf
linecode b8zs
description PRI PSTN #1
controller T1 0/1/1
framing esf
linecode b8zs
description PRI PSTN #2
controller T1 0/2/0
framing esf
linecode b8zs
description PRI PSTN #3
no ip address
trunk-group PSTN
no cdp enable
interface Serial0/1/1:23
no ip address
trunk-group PSTN
no cdp enable
interface Serial0/2/0:23
no ip address
trunk-group PSTN
no cdp enable
voice-port 0/1/0:23
voice-port 0/1/1:23
voice-port 0/2/0:23
direct-inward-dial
trunkgroup PSTN
Hall of Fame Super Gold
Re: Using Trunk Groups for Incoming Calls from PSTN
Hi Johnny,
trunk-groups, just like voice-ports, make no sense for incoming, because they play no role in the selection of the incoming DP.
It used to be otherwise, but that has (silently) changed for reasons I can explain if you want.
To verify what I'm saying, try removing "port" from your DP 1. You should have direct-inward-dial still working with no problem. To further prove, configure another DP, with a valid specified "incoming called-number", but no port and no direct-inward-dial. Calling that number should give you dialtone.
Hope this helps, if so please rate post!
Bronze
I'll take your word for it :)
So I tested this:
direct-inward-dial
And that worked fine, and should match the call regardless of which PRI it comes in via.
When I found this, I couldn't take the word of the documentation that still currently says otherwise.
So I brainstormed and came to the conclusion that the documentation is right as long you read it in a critical way, complement with more reading and testing, and periodically contact the writers to make it "even more right" :)
As a courtesy to those providing answers, please rate all useful posts using the scrollbox below!
567
