Validate digits outpulsed on DID analog trunks
Verizon and I are going back and forth about the provisioning of a trunk group. The trunks in question are DID groundstart trunks using wink-start signaling. The trunks are connected to a VIC-4FXS/DID card plugged into a 2811 running 12.4(23) code.
Verizon says they are outpulsing 4 digits but it does not look like that to me.
Of the numbers ported to this group 3 work and 5 do not. As I read the output of "debug voip ccapi" they are only sending me 1 or 2 digits on the non-working numbers.
I have attached the output of "show debug ccapi" for a nonworking call. On this call verizon should have outpulsed 6993.
My questions are:
1) What is the easiest and surest way to verify what digits the carrier is providing me.
2) Is there anything in my config that could cause this?
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Validate digits outpulsed on DID analog trunks
Take "debug vpm signal". No other debugs are necessary. Also please configure "service timestamps log datetime msec".
There maybe a need to adjust timing on the port so send the output fo "show voice port" for the relevant one.
Thanks for the debug info. That is exactly what I needed. Verizon finally figured out they screwed up and are resolving it as we speak. Thanks for the help and enjoy the 5 points!
Very good, analog DID are not friendly animals. Thanks for the nice rating and good luck!
339
