Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
VCS VS EXPRESSWAY
Guys clarify me VCS-C & E vs EXPRESS WAY-C&E what is the major difference?
VIP Purple
Hi Siva,VCS basically comes
Hi Siva,
VCS basically comes in two modes : one is VCS Ctrl and other is VCS -Expressway.
VCS Ctrl is used for registering third party video endpoints.It helps enable interworking of Telepresence endpoints with H.323 and third party video endpoints[Polycom/MsLync]
VCS-E with Ctrl is used for dialing from internet.
regds,
aman
What abt Expressway -C &E
Silver
Yes, Cisco didn't make it
Yes, Cisco didn't make it easy for us.
The word Expressway is used for several products. But important to know is that VCS is the Tandberg product and is a sort of callmanager.
Expressway C and E is not a callmanager, meaning you can't register devices on it, and it provides functionality like Lync Edge (VPN less connection)
But, and here comes the confusing part, all products are based on VCS code. So there is no Expressway-C and E software, only VCS software, and the license installed make it what you want it to be.
Here is a good link:
www.cisco.com/web/HR/ciscoconnect/2014/pdfs/20140403_cisco_connect_see_expressway.pdf
Hope it is clear
Jan
317
