Community Member
Verify Hotfixes and Patches
How can I verify hotfixes and patches that have been applied to Windows 2000 server
Re: Verify Hotfixes and Patches
I usually go to start---->settings----->control panel----->add/remove programs....scroll through this list and you should see which hotfixes have been applied to your server.
Hope that helped, if so please rate.
very simple, go to add/remove programs and you will see them
java
if this helps, please rate
java
www.cisco.com/go/pdi
101
